Version 1.10.4.0 of PWPS_DAB just posted to the PowerShell Gallery
We just posted version 1.10.4.0 of the #PWPS_DAB #PowerShell module for #ProjectWise to the PowerShell Gallery. To install: Run an Admin session of 32-bit PowerShell v5 and use the cmdlet Update-Module PWPS_DAB (if you already have the module) or Install-Module PWPS_DAB (for a new install). One can run Uninstall-Module PWPS_DAB first just to clean up old installs. VERY IMPORTANT NOTE: This PowerShell Module is not covered under your SELECT Agreement and is not supported via your contractual support channels. Support is only available via the BE Communities site ( communities.bentley.com/.../projectwise-powershell-extensions-forum ).
  • 2019-04-12 Version 1.10.4.0
    Added cmdlets
    • Convert-PWFolderToRichProject
    Changed cmdlets
    • Update-PWStorageAreaForProjectTree
      • added -SourceStorageArea parameter.
    • Add-PWValidationQRCode, Add-PDFQRCode, Add-PWPDFQRCode
      • changed the way we define the location of the code image. Now is always from lower left of page as it opens and regardless of actual rotation and units are "points" which is 1/72nd of an inch.
    • Import-PWProjectAccessControl
      • fixed bug where existing access control was not being removed before applying new access control.
    • Export-PWProjectAccessControl
      • updated the way the rights masks are generated. Should be more reliable.
