Access is Denied when installing pwps_dab module
In the recent pwps_dab (1.10.3.0 and above) module updates I have run into an issue installing / upgrading the module in the 32 bit ISE. I am not aware of any changes to my computer that would be causing the issue. I am running the ISE as admin.
Here is the output I get from the install-module attempt.
VERBOSE: Using the provider 'PowerShellGet' for searching packages.
VERBOSE: The -Repository parameter was not specified. PowerShellGet will use all of the registered repositories
VERBOSE: Getting the provider object for the PackageManagement Provider 'NuGet'.
VERBOSE: The specified Location is 'www.powershellgallery.com/.../' and PackageManagementProvider is
'NuGet'.
VERBOSE: Searching repository 'www.powershellgallery.com/.../FindPackagesById() for ''
VERBOSE: Total package yield:'1' for the specified package 'pwps_dab'.
VERBOSE: Performing the operation "Install-Module" on target "Version '1.10.5.0' of module 'pwps_dab'".
VERBOSE: The installation scope is specified to be 'AllUsers'.
VERBOSE: The specified module will be installed in 'C:\Program Files (x86)\WindowsPowerShell\Modules'.
VERBOSE: The specified Location is 'NuGet' and PackageManagementProvider is 'NuGet'.
VERBOSE: Downloading module 'pwps_dab' with version '1.10.5.0' from the repository 'https://www.powershellgaller
y.com/api/v2/'.
VERBOSE: InstallPackage' - name='pwps_dab', version='1.10.5.0',destination='C:\Users\3830a\AppData\Local\Temp\15
40773918'
VERBOSE: DownloadPackage' - name='pwps_dab', version='1.10.5.0',destination='C:\Users\3830a\AppData\Local\Temp\1
540773918\pwps_dab\pwps_dab.nupkg', uri='www.powershellgallery.com/.../1.10.5'
VERBOSE: Downloading 'www.powershellgallery.com/.../1.10.5'.
VERBOSE: Completed downloading 'www.powershellgallery.com/.../1.10.5'.
VERBOSE: Completed downloading 'pwps_dab'.
VERBOSE: Hash for package 'pwps_dab' does not match hash provided from the server.
VERBOSE: InstallPackageLocal' - name='pwps_dab', version='1.10.5.0',destination='C:\Users\3830a\AppData\Local\Te
mp\1540773918'
PackageManagement\Install-Package : Access is denied
At C:\Program Files (x86)\WindowsPowerShell\Modules\PowerShellGet\1.0.0.1\PSModule.psm1:1772 char:21
+ ... $null = PackageManagement\Install-Package @PSBoundParameters
+ CategoryInfo : NotSpecified: (Microsoft.Power....InstallPackage:InstallPackage) [Install-Packag
e], Exception
+ FullyQualifiedErrorId : System.UnauthorizedAccessException,Microsoft.PowerShell.Commands.GetChildItemCom
mand,Microsoft.PowerShell.PackageManagement.Cmdlets.InstallPackage
I am still able to get it installed in the 64 bit ISE though I have not used that version.
Thanks...
