Move-PWDocumentsToFolder fails
I wanted to post this and see if others have seen this issue.
If you use Move-PWDocumentsToFolder, with the -CreateVersions switch enabled, does it fail for you too?  The command fails if the folder that I am moving to documents too doesn't actually contain a document.
Hope this makes sense,
Kirk
