Projectwise Powershell cmdlet Request for setting the Work Area Type
Can you please create a ProjectWise Powershell cmdlet that will add/set the project Work Area Type when a Rich Project is created?
  • I was able to do this with Update-PWRichProjectsFromSpreadsheet by first running Get-PWRichProjectReport for the Work Area that doesn't have a type, then editing that excel file, and then using it as input for the Update-PWRichProjectsFromSpreadsheet Cmdlet.
    There might be other ways, but this approach seems to work.
    I was using PWPS_DAB version 1.15.1.0, but in 32-bit mode.  There appears to be a bug in the 64-bit version that is being investigated.
    Dan Williams
    Solution Consultant
    Bentley Systems, Incorporated
    Portland, OR, USA (Pacific Time UTC-08:00)
