Create a Saved Search programmatically with multiple conditions
Hello Teams,
On a project I am requirement to create a saved Multiple  saved search programmatically. The requirement is
#1) The list of files is between 10 to 20 documents, they are in different folders and does not have pattern in the file format that can be used.
#2) The exact document name and version number will be provided, say for this sample would be  Name: DOC1  Rev.ver: P11 ,Name: DOC2 Rev.ver.:P12, … Name: DOC15 , Rev.ver:W00
#3) The files are of the type Revit
Based on the sample files script provided I only see one criteria
Add-PWSavedSearch -SearchName 'Search01' -SearchFolder 'Top Level\Project 01\RVT'
-SearchSubFolders -DocumentName 'Doc1'
- FileName %.rvt
-Attributes @{Rev.Ver = "P11";}
-States "Default" -Verbose
Question:
How do I add multiple Search criteria which I can from the "ADD OR Group" to add multiple criteria (image 1)
The attribute column should be display text or internal attribute name.
RJ
