When using Export-PWDocumentsToArchive, the cmdlet exports the Work Area Types and attributes so they can be imported into a different datasource and created. However, if the Work Area Type Name changes, the Export-PWDocumentsToArchive still exports the original Work Area Type Name and does not match the updated name of the Work Area Type. Can this be updated to export that name to the current name and not the original?
-Richard
I realize this is an old post, however it may still be relevant for some users. You could update the SQLite DataBase to reflect the Work Area name in the target datasource prior to running the import process.
