Version 1.21.6.0 of PWPS_DAB just posted to the PowerShell Gallery
We just posted version 1.21.6.0 of the #PWPS_DAB #PowerShell module for #ProjectWise to the PowerShell Gallery. To install, from a 64-bit Admin session of PowerShell v5 run: [Net.ServicePointManager]::SecurityProtocol=[Net.SecurityProtocolType]::Tls12, Uninstall-Module PWPS_DAB -AllVersions -Force, Install-Module PWPS_DAB. VERY IMPORTANT NOTE: This PowerShell Module is not covered under your SELECT Agreement and is not supported via your contractual support channels. Support is only available via the BE Communities site ( communities.bentley.com/.../projectwise-powershell-extensions-forum ).
  • 2020-06-22 Version 1.21.6.0
    Added Cmdlets
    • Get-PWDocumnentByURN
      • returns a document object when given a URN copied from PW Explorer.
    • Get-PWFolderByURN
      • returns a folder object when given a URN copied from PW Explorer.
    Changed cmdlets
    • Export-PWDocuments
      • fixed bug with setting last update date on exported files.
    • Copy-PWConnectedProjectSettings
      • fixed bug having to do with locating source connected project for copy.
