Version 1.21.8.0 of PWPS_DAB just posted to the PowerShell Gallery
We just posted version 1.21.8.0 of the #PWPS_DAB #PowerShell module for #ProjectWise to the PowerShell Gallery. To install, from a 64-bit Admin session of PowerShell v5 run: [Net.ServicePointManager]::SecurityProtocol=[Net.SecurityProtocolType]::Tls12, Uninstall-Module PWPS_DAB -AllVersions -Force, Install-Module PWPS_DAB. VERY IMPORTANT NOTE: This PowerShell Module is not covered under your SELECT Agreement and is not supported via your contractual support channels. Support is only available from the community of users via the BE Communities site (see below).
  • 2020-06-23 Version 1.21.8.0
    Added Cmdlets
    • Get-PWDocumentCopyOutLocationCounts
      • returns document copy out location record counts by node or user or date.
    • Remove-PWDocumentCopyOutLocations
      • remove document copy out location records by nodes, users, or date.
    Changed cmdlets
    • Import-PWDocuments
      • added -ValidationReport parameter.
