Unable to install 32-bit Module
I have run uninstall-module -name 'pwps_dab' -force -allversions on 32-bit ISE and 64-bit ISE and ran install-module -name 'pwps_dab' in the 64-bit ISE with no issues. I see the folder created here: C:\Program Files\WindowsPowerShell\Modules\, but no folder shows up in the 32-bit location here: C:\Program Files (x86)\WindowsPowerShell\Modules\. Explicitly running the install-module in the 32-bit ISE doesn't appear to do anything, no progress bar, but no errors either and no folder shows up. When attempting to use new-pwlogin in the 32-bit ISE I get the message:
WARNING: Error: Unable to load DLL 'dmscli.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E
   at PWPS_DAB.Utility.aaApi_Initialize(Int32 init)
   at PWPS_DAB.Utility.InitializePWAPI(Int32 init)
   at PWPS_DAB.NewPWLogin.ProcessRecord()
False
New-PWLogin : The type initializer for 'PWWrapper' threw an exception.
At line:1 char:1
+ New-PWLogin
    + CategoryInfo          : NotSpecified: (:) [New-PWLogin], TypeInitializationException
    + FullyQualifiedErrorId : System.TypeInitializationException,PWPS_DAB.NewPWLogin
From what I gather reading similar posts, the 64-bit install should be installing for 32-bit as well.
Any insight is appreciated.
