Check if a CONNECT project has Deliverable Management Enabled?
Hi all,
I am using the Add-PWUsersToConnectedProjectByUserLists cmdlet to "sync" user access between PWDI and its associated CONNECT project.
The one issue ive found is that it doesn't do anything if the CONNECT project doesn't have Deliverables Management module turned ON (which is the case by default).
Is there any way in Powershell to first check if Deliverable Management is enabled for a CONNECT project instead of getting the false impression users are being added?
Mark
