Folder name yy\xx was found with ID 0
Hi All,
I would like to change the environment of few folders and its documents.
I'm using Brian's below blog as reference.
https://powerwisescripting.blog/2018/08/30/how-to-change-the-environment-on-a-project-with-documents/
Connection to PW datasource is successful.
When i was running the command
$folders = Get-PWFolders -FolderPath "Documents\Rendition testing" -JustOnce -Verbose
I'm getting below error.
VERBOSE: Looking for folder 'Documents\Rendition testing'
VERBOSE: Folder 'Documents\Rendition testing' was found with ID 0
WARNING: 'Documents\Rendition testing' is not a valid folder name
Any suggestion would be helpful.
I'm using PowerShell ISE(x64) with pwps_dab version = 1.23.8.0
