Get-PWDocumentsBySearch Documents Not Found
I have encountered a problem with the Get-PWDocumentsBySearch Cmdlet.
The code is:  $docs = Get-PWDocumentsBySearch -FolderPath $Document_Path -GetAttributes {$_.name -eq "Test Document%"}
The PowerShell transcript reports the following errors:
PS H:\> TerminatingError(Get-PWDocumentsBySearch): "Illegal characters in path."
Get-PWDocumentsBySearch : Illegal characters in path.
You cannot call a method on a null-valued expression.
I have checked the obvious points such as variable values, search path. The path is defined as a text string with quotaion marks (" ").
In this example there are two documents which meet the path and name criteria.
Any support would be appeciated.
