Feature request: Populate date/times on Get-PWDocumentsBySearch when -PopulatePath is used
To be as fast as possible Get-PWDocumentsBySearch only populates the DocumentUpdate date by default. But it seems like a waste to use -Slow when you just want dates, so would it be possible that when the medium speed option -PopulatePath is specified to also return the dates for CreateDate, FileUpdateDate, and DocumentUpdateDate?
Or alternatively add a -PopulateDates option that fills in just those attributes. If both path and dates are needed, use both options.
Kevin
