Bentley Transmittal Services Data Export Tool
(Moved from Content management)
I am having trouble getting the export tool to work:
Setup Details:
BTS SQL Server name: WAV-PWTSQL
BTS Database name: BentleyTransmittalServerDB
PW SQL server name: WAV-PWSQL
PW SQL Database name: PWDATA
User: msaxon.adm – has access to the two SQL databased in question, am logged on to integration server as msaxon.adm
Folder nominated for export and containing the supplied scripts - g:\BTSExport\
Powershell run from Integration server.
Script:
g:\BTSExport\BTS_Export.ps1 -btsDbConnectionString “Server=WAV-PWTSQL;Database=BentleyTransmittalServerDB; Trusted_Connection=True;”
-pwDbConnectionString “Server=WAV-PWSQL;Database=PWDATA;UserId=msaxon.adm;Password=***********;” -tryComAutofit
It runs the first half of the script and then prompts me:
PS G:\btsexport> g:\BTSExport\BTS_Export.ps1 -btsDbConnectionString “Server=WAV-PWTSQL;Database=BentleyTransmittalServerDB; Trusted_Connection=True;”
-pwDbConnectionString “Server=WAV-PWSQL;Database=PWDATA;UserId=msaxon.adm;Password=*********;” -tryComAutofit
cmdlet BTS_Export.ps1 at command pipeline position 1
Supply values for the following parameters:
If I then manually enter the -pwDbConnectionString I get
Exception calling ".ctor" with "1" argument(s): "Keyword not supported: '“server'."
At G:\BTSExport\BTS_Export.ps1:132 char:5
+ $pwDbConnection = [System.Data.SQLClient.SQLConnection]::new($pwD ...
+ CategoryInfo : NotSpecified: (:) [], MethodInvocationException
+ FullyQualifiedErrorId : ArgumentException
You cannot call a method on a null-valued expression.
At G:\BTSExport\BTS_Export.ps1:137 char:1
+ $pwDbConnection.Open()
+ CategoryInfo : InvalidOperation: (:) [], RuntimeException
+ FullyQualifiedErrorId : InvokeMethodOnNull
No connection to the database detected. Run command ConnectToDB first.
At G:\BTSExport\BTS_Export.ps1:51 char:13
+ Throw "No connection to the database detected. Run comman ...
+ CategoryInfo : OperationStopped: (No connection t...nectToDB first.:String) [], RuntimeException
+ FullyQualifiedErrorId : No connection to the database detected. Run command ConnectToDB first.
