PowerShell 7
Is it possible to load pwps_dab in PowerShell7?  When I try to import it, I get the following error message:
Import-Module: Could not load file or assembly 'BTSTypes, Version=9.99.99.99, Culture=neutral, PublicKeyToken=null'. The system cannot find the file specified.
I tried using Import-Module pwps_dab -UseWindowsPowerShell and that seems to work, but some functions are not recognized, such as Get-PWFoldersImmediateChildren
Is there a trick that will make pwps_dab load in PowerShell 7?
