Add-PWConnectedProjectUsersOIDC used to add uses, can you apply a role at the same time?
Adding users to a Connected project up to this point I have been using the following code successfully for the past few weeks,
$bentleyToken = Get-PWConnectionClientToken
Add-PWUsersToConnectedProject -ConnectedProjectId $connProjID -Token $bentleyToken -Emails $UserEmails -Roles $roles
But increasingly I'm having issues with the Token returning 'Can't read token warning, which I can't seem to work out why its not working as I have latest PW admin and DM installed.
So I decided to go with this,
$OidcToken3 = Get-OIDCToken -Authority https://ims.bentley.com -ClientID powershelltokengen -Verbose
Add-PWConnectedProjectUsersOIDC -OIDCToken $OidcToken3 -ConnectedProjectIds $projectArray -Emails $userArray
And it works, I can add an array of users to an array or connected projects, but there is no option to add the users to a role.
I have tried this, but I have the same problem as above where the token is not read.
Add-PWConnectedProjectUsersToRoles -ConnectedProjectId $Connectedproject -Roles "PS0 Viewer" -Token $bentleyToken
Is there another option to add Users to a Role in a connected project?
Is there a way to debug Get-PWConnectionClientToken using Bentley IMS 2FA?
Any help would be appreciated.
Ray
