PDF output from Autocad
When plotting directly from AutoCAD to PDF using the DWGtoPDF.pc3, the PDF is saved to ProjectWise but the message "PDF Output - No PDF Viewer Installed" is displayed and the newly plotted PDF is not opened.
The default (when working outside of ProjectWise) is that the new PDF is opened for viewing after the plotting is complete. My users are complaining and I would like to fix this if possible.
  • Have you tried opening the PDF file created inside ProjectWise with Adobe to make sure it is a good PDF file? Is the same machine used when creating the PDF file inside and outside ProjectWise? Also make sure the user does have an Adobe product loaded on the machine for opening the PDF files.
