I created new Iplot server on windows 2016 DataCenter server.
When I go to the License Management Tool and look at the Activation Status I don't see the Bently View or the ProjectWise InterPlot Organizer listed like I see on my 3 other servers they are Window 2008R2.
The reason I'm checking this is when I try plotting from this server and I choose a printer to test from this new server after fencing the drawing and say ok I get an error message. "NOSUCHFORM, paper size "11x17" is not valid for printer and it gives path.
By the way, I choose to do a printer migration.
The error message usually means that the client is unable to communicate with the print server.
Please carry out the following steps on the client machine and check the Interplot prints again-
ProjectWise Interplot Organizer and Bentley View does not need to be activated on the print server machine for Interplot printing executed from the user machine. However you can activate if you use those products inside the server machine-
https://docs.bentley.com/LiveContent/web/ProjectWise%20Administrator%20Help-v9/en/GUID-7065BBF2-A2FD-4DAA-BD72-2491C7D901E0.html
In case you face this issue, you might want to check the compatibility of the Interplot products with the Operating System on both the client and the print server.
