In Microstation under Print - Raster Options we can reduce the raster Quality factor. Is there a way of doing this is the .set settings file setup via the Design Script or similar ?
Hi Gareth,
Yes, IPLOT_RASTER_QUALITY can be set via an InterPlot settings file.
Please note: ProjectWise InterPlot Organizer 10.00.01.22 or later is required, and IPLOT_SET_IPARM_CFGVARS=TRUE will need to be added to iplot.cfg on the iCS for PDF server.
