Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Announcements Forum ProjectWise WebServer Module for SharePoint 2013 and IE 11
    • Sign In
    • Locked Locked
    • Replies 1 reply
    • Subscribers 110 subscribers
    • Views 5067 views
    • Users 0 members are here
    • ProjectWise IE 11 support
    • Web server
    • ProjectWise
    • SharePoint 2013
    Vickie Ramsey
    Offline Vickie Ramsey over 8 years ago
    Today we have released support for SharePoint 2013 integration with ProjectWise. This allows users to integrate SharePoint 2013 with ProjectWise WebServer.  Below is  the download description from SELECT Downloads with some important information about the integration.
    Download Description:
    ProjectWise is software for connecting people and information across distributed teams and is used by architects and engineers to manage, find, and share CAD and geospatial content, project data, and Office documents. ProjectWise Integration Server is an enterprise-level engineering content management solution.
    The ProjectWise V8i WebServer Module for SharePoint 2013 08.11.11.833 download contains the installation package needed to support IE 11 and SharePoint 2013 integration with ProjectWise WebServer.
    The ProjectWise V8i WebServer Module for SharePoint 2013 08.11.11.883  works with ProjectWise Integration Server V8i (SELECTseries 4) (08.11.11.590) and is intended for organizations who are using SharePoint 2013 or standalone IIS and IE 10/11.
    ***SharePoint 2013 is not a requirement.
    It does not include SharePoint search integration or support for SharePoint 2007 or 2010.  This release does not deliver ProjectWise Publishing Gateway Service, so if you need to integrate ProjectWise Web Server with ProjectWise Publishing Server you must use the ProjectWise Publishing Gateway Service that is delivered with ProjectWise V8i (SELECTseries 4) Server Setups (08.11.11.590) and provides the following capabilities:
    • create documents 
    • check out and open documents 
    • open documents as read-only 
    • move and delete documents 
    • export documents 
    • free documents 
    • view thumbnail images of documents 
    • display set contents 
    • compare the graphical differences of two DGN documents 
    • create various types of links to documents 
    • purge local copies of documents from the working directory 
    • create, modify, and delete folders 
    • right-click menu added to the Navigation web part 
    • view the component tree, show component  properties, and zoom in to components 
    • view spatial data in the new Spatial Content web part
    • Additionally, many other fixes and correction were completed.
    For a more comprehensive list of new features and compatibility considerations for ProjectWise V8i WebServer Module for SharePoint 2013 please see the Readme.
    Notes:
    ProjectWise Web Server 08.11.11.833 works with ProjectWise Integration Server V8i (SELECTseries 4) (08.11.11.590) and ProjectWise Design Integration 10.00.00.20 & 10.00.01.25 and is intended for organizations who are using SharePoint 2013 and IE 10/11.
    **This release does not deliver ProjectWise Publishing Gateway Service, so if you need to integrate ProjectWise Web Server with ProjectWise Publishing Server you must use the ProjectWise Publishing Gateway Service that is delivered with ProjectWise V8i (SELECTseries 4) Server Setups (08.11.11.590).
    • Cancel
    • JackiS
      Offline JackiS Wed, Feb 25 2015 6:23 AM
      Note: This release of the PW Web Server module supports both SharePoint 2013 and standalone IIS, IE 10 and 11. It was tested with both Windows 2008 R2 SP1 and Windows 2012 R2 server. Please see install guide.
      • Cancel
      • Vote Up 0 Vote Down
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
