ProjectWise Design Integration Update 3.3
Released Modules:
The ProjectWise DI team is happy to announce the availability of ProjectWise Design Integration 3.3. A key capability in this release is in PW Web where users can now edit a document's environment attribute values, change the environment interface, as well the availability of PWDI Views in PW Web. This release includes the following modules
Release Notes:
While this release includes a ProjectWise Administrator module that does not have a corresponding PWDI Server version, the rule about mixing versions on the same machine still apply. The reason for this is to allow both ProjectWise Administrator 3.3 and ProjectWise explorer version 3.3 to be installed on the same machine. This version of ProjectWise Administrator can only be used to administer a 10.00.03.2XX ProjectWise Datasources. This version of ProjectWise Administrator cannot be installed on the same machine as PWDI 3.2 Server. It can only be installed alongside a machine that also has PW Explorer 3.3.
Hi Phil,
When will the full list of resolved issues and updated readme be published at - docs.bentley.com/.../index.html ?
Can you provide some additional info on the 'Improved handling of AutoCAD printing' item? One thing we requested was the ability to load from a document set or to easily import multiple documents via the integration with the BATCHPLOT AutoCAD tool. Is that part of the improvements in this version?
Sean
Hi Sean, I will have the full list uploaded later today. The updated readme and updated 3.3 documentation is being synced to the doc.bentley.com site and should be available soon. We can talk about the enhancement request on our call later today.
I seem to get Fatal Errors on opening AutoCAD 2020 after installing PWDI 3.3, both upgrading and after uninstalling and re-installing. Seems to work ok if i install the old seperate AutoCAD 2020 module?
Mark
OpenRoads Designer 2022 R3 (10.12) | Microstation CE Update 17.2 | ProjectWise CE 3.4
Hi Phil. Can you please advise where the ProjectWise Web WSG Plugin (10.00.03.331) can be found on the downloads site? Also, why is the PW Explorer download not shown when a search for PWDI 10.00.03.329 is done - it only shows Admin. Finally found it after searching for Explorer but a nit misleading...
Hi Steve, when there is a full PWDI release that includes the server, all 3 modules (client.server,admin) are under the PWDI page. When it is a PW Explorer only release (no server), than the download is only listed under the ProjectWise Explorer Client product page. I can work with the team that manages the downloads to make improvements moving forward. The WSG plugin ran into a posting issue that the team is working on resolving. It should be visible in the next day or two.
