ProjectWise Integration Module for Revit 2021.1 is now available for download:
The ProjectWise Integration Module for Revit download contains the installation package needed to integrate Revit 2021.1 with ProjectWise Explorer.
Does this version support Revit 2021.1.2 ?
Using ProjectWise Explorer 10.00.03.334, and Revit Integration Module 10.00.03.618:
We can install the integration module successfully on systems with Revit 2021.1.1, however if Revit 2021.1.2 is installed then the integration installer fails with the error window:
"Autodesk Revit 2021 is required to install ProjectWise Integration for Autodesk Revit 2021".
Clicking the OK button then displays the message "Setup Wizard Completed. The Wizard was interrupted before ProjectWise Integration for Autodesk Revit 2021 could be completely installed. Your system has not been modified. To complete the installation another time, please run setup again."
We then tried ProjectWise Explorer 10.00.03.434 (which includes the Revit 2021 integration module), but installation fails when it gets to the Revit 2021 integration installation part ("Failed to install ProjectWise Integration for Autodesk Revit 2021...Fatal Error during installation).
Hello Martin,
Did you find a resolution for this issue? I am seeing the same behavior with PW Explorer 10.00.03.334 and the Revit 2021 Integration 10.00.03.618. We are also using Revit 2021.1.2 and the Integration install fails to recognize Revit 2021 is already installed.
Thank you.
Hoang
Hello Hoang,
No, the issue has not been resolved. We also tried using the PW Explorer installer 10.00.03.434 which includes a Revit 2021 integration module, but that integration also failed to Install on systems with Revit 2021.1.2.
Is there a VBA library or SDK of this plug in?We need to harvest the attachments and their versions and they just doesnt seem to be a way? It is very important from a QA perspective
Is there a resolution or work around for this issue? I've had to disable Revit 2021 integration just to get PW v10.00.03.434 to even install.
Mike
