ProjectWise Web Update - September 2022
The changes are available in ProjectWise Work Area Connections application in CONNECT and Document section in ProjectWise 365.
  • Updated gird and modal screen UI components
Consistent with new UI standards. No functionality changes to users. Improved performance and usability in large folders
  • Document references downloaded in the same folder
References are added to the root of a zip file instead of a subfolder when downloading document with references. This will make discovery of references easier in downloaded files.
  • Automatically open first connection when visiting projects for the first time
  • Improved first page loading time in datasources that have large number of saved searches
  • Issues fixed:
    • Improved error message when opening a link to a deleted connection
    • Prevent description from being overwritten when using version option in file conflict resolution screen
    • Other fixes
