It seems that from inside our company we have issues logging into Connect. Is there a port other than 80 that the login uses? Is there some configuration that our internet support could allow?
Dean, I would suggest you look at support solution of CONNECTION client FAQ: http://communities.bentley.com/communities/other_communities/sign-in_assistance_and_web_services/w/wiki/23899.connection-client-faq
or at this forum post with the same Navigator CONNECT Edition proxy issue: http://communities.bentley.com/communities/other_communities/sign-in_assistance_and_web_services/f/343368/t/110808
Darius
Tamicca SellarsProduct Manager I
