Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
[Archived] Project Review Forum Open a dwg and see the blocks/cells in the cell lib
    • Sign In
    • State Not Answered
    • Replies 2 replies
    • Subscribers 11 subscribers
    • Views 1887 views
    • Users 0 members are here
    NicolasT
    Offline NicolasT over 7 years ago
    In MicroStation, when I open a DWG with blocks, I can see all these blocks/cells listed in the active (named "none" cell library. So I can place the same cells.
    In Navigator when I open the dwg, these cells are not available in the cell library. Is there a way to fix this ? Or can I default attach a cell library (or several libraries) in Navigator when it starts ? Could the cell selector be available ? Thanks
    • Sign in to reply
    • Cancel
    • Paul Johnson
      0 Offline Paul Johnson Thu, Jan 14 2016 1:12 PM
      Hello Nicholas - this same issue exists in MicroStation. The 'gothca' here is that Navigator doesn't open your DWG directly, it creates an overlay.dgn and attaches your DWG to it. If you were to create that same scenario in MicroStation (attach your dwg as a reference to a dgn file) you'd see the same behavior. The solution at this time is from within the Cell Library dialog - do a FIle>Attach and attach the DWG as a cell library to the overlay.dgn. I hope this helps.
      ~Paul
      This is a test
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • NicolasT
      0 Offline NicolasT Fri, Jan 15 2016 6:11 AM in reply to Paul Johnson
      Thank you very much indeed Paul. It's a workable work-around, much appreciated :)
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
