I am unable to attach a reference or raster file from ProjectWise, CONNECT goes straight to windows dialog box skipping ProjectWise dialog box. The .dgn file is opened straight from ProjectWise. It worked well while using v8i SS3 previously.
Re-installed ProjectWise, but that didn't fix the problem. i-Desktop integration node did not have CONNECT in the list of applications.
Any thoughts? Is there any way to set MiroStation v8i SS3 to be the default software when I open .dng file from ProjectWise while keeping CONNECT installed?
I am running MiroStation CONNECT 10.01.00.13 Update 1 and ProjectWise Explorer V8i (SELECTseries 4) 08.11.11.559.
Hello, Nikolay,
We need to look at compatibility, and this these versions were not compatible, this is why you could not attach anything from ProjectWise. Yes you can set up default application right click on document > open with... > those wanted application and check "Always use this program."
