Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
[Archived] Project Review Forum Navigator CE Update 3 with 2D files?
    • Sign In
    • State Not Answered
    • Replies 1 reply
    • Subscribers 11 subscribers
    • Views 998 views
    • Users 0 members are here
    Jan Šlegr
    Offline Jan Šlegr over 7 years ago
    I tried Bentley Navigator CONNECT Edition Update 3 with new MicroStation CONNECT Edition Update 3. I published example GISdata.dgn, but it seems it does not work, because Navigator is able to load the file (locally), but it's not able to open a view and display:"Loading" indicator is displayed and there is no other reaction?
    Is it because 2D files are (still) not supported?
    With regards,
      Jan
    • Sign in to reply
    • Cancel
    • Ken Shigemitsu
      0 Offline Ken Shigemitsu Fri, Oct 28 2016 2:16 PM
      Hi Jan,
      I was told by Bentley that the next update of Navigator will likely to include 2d capabilities, but from what I see in your post that is not to be the case on update 3, which is disappointing. We have a lot of annotations generated by the Dynamic views (2D). I wanted to incorporate these plans as part of the supporting files for coordination in Connection Edition. During my test, I actually found a workaround to put annotations generated by Dynamic views into I-model and publish it to the portal to be shared in Navigator Connection. For now, I will use this technique to satisfy my users' request. You can use the following technique as an interim solution. 1. Open the DV view model in Microstation Connection. 2. Save as another copy then export to 3D. 3. Merge all external models into one. 4. Export to HLN and output as 3D. 5. publish it as i-model. I am in the process of automating this using MVBA.
      Give it a try and good luck.
      Ken
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
