Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
[Archived] Project Review Forum Microsoft .NET error
    • Sign In
    • State Verified Answer
    • Replies 6 replies
    • Subscribers 11 subscribers
    • Views 2415 views
    • Users 0 members are here
    • markups
    • KeyIn
    • Navigator
    Tamas Dravai
    Offline Tamas Dravai over 4 years ago
    I'm using Navigator v8i(SELECTseries 6) Version 08.11.09.713. When I try to use the keyin "markup export all" or "markup export active" I get a Microsoft .NET Framework error. I attached a screenshot of the error message. This issue was also replicated on another laptop with a different model using Navigator v8i(SELECTseries 4) Version 08.11.09.293 . The same error message occurs.
    It's running on a Windows 10 machine with all the latest Windows updates. I've already tried running the .NET repair tool and installed the latest version of the .NET framework. Navigator itself was also uninstalled and reinstalled.
    Does anyone have any suggestions for troubleshooting?
    Best regards,
    Tamas
    • Sign in to reply
    • Cancel
    Top Replies
    • Jan Šlegr
      Offline Jan Šlegr Tue, Oct 16 2018 8:41 AM +1 verified
      Hi Tamas, another question / thought: How do you use the key-ins? Do you use the key-ins exactly as you wrote ("markup export all" and "markup export active")? In Navigator help it's specified that…
    • Tamas Dravai
      Offline Tamas Dravai Tue, Oct 16 2018 10:00 AM in reply to Jan Šlegr +1 verified
      Hi Jan, Thank you for your help, it steered me in the right direction and I managed to solve it now. The problem was that the markups dialog window wasn’t open when I tried to export the active markup…
    • Jan Šlegr
      0 Offline Jan Šlegr Mon, Oct 15 2018 11:45 AM
      Hi Tamas,
      Navigator is based on quite old NET 3.5, not the latest 4.x, so to install "the latest" probably will have not any effect.
      Is NET Framework 3.5 installed on your computer? This version is not installed by default and has to be added manually. On the other hand I assume without the framework installed, it would not be possible to install Navigator.
      With regards,
        Jan
      Bentley Accredited Developer: iTwin Platform - Associate
      Labyrinth Technology  |  dev.notes()  |  cad.point
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Tamas Dravai
      0 Offline Tamas Dravai Tue, Oct 16 2018 6:17 AM
      Hi Jan,
      Thank you for the reply. Yes I've gone through the registry and the .NET Framework 3.5 is installed.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Tamas Dravai
      0 Offline Tamas Dravai Tue, Oct 16 2018 6:53 AM
      Would it be possible to attack the problem from a different angle? Could there be another way to export markups using VBA other than the key-in command?
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Jan Šlegr
      +1 Offline Jan Šlegr Tue, Oct 16 2018 8:41 AM
      Hi Tamas,
      In Navigator help it's specified that the key-in is "MARKUP EXPORT [ ACTIVE | ALL | RELATED ] <PATHname> <filename>", so maybe Navigator crashes because you do use key-in incorrectly without file with path specification?
      With regards,
        Jan
      Answer Verified By: Tamas Dravai
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Reject Answer
      • Cancel
    • Tamas Dravai
      +1 Offline Tamas Dravai Tue, Oct 16 2018 10:00 AM in reply to Jan Šlegr
      Hi Jan,
      The problem was that the markups dialog window wasn’t open when I tried to export the active markup. If I open the markup dialog and then run the keyin it works correctly. I assume that until this dialog is opened there is no active markup and that’s why it crashed.
      • Cancel
      • Sign in to reply
      • Reject Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
