Why the tags disappear from the element when I open the Imodel format on the navigator, although it has before publishing to Imodel.
Hi Nadeem,
please respect the communities best practices. It's hard to answer for anybody when it's not clear what product (and version) you used to create i-model and also what version of i-model you created (there are old 1.5, current 1.6 and the newest 2.0).
NADEEM.DWEIB@GMAIL.COM said:Why the tags disappear
I think it's because they are not supported in i-model format, so they are removed during the publishing process.
Tags are very old (based on DGN V7 format), limited and not robust. If you want to attach data to elements in a format that will be maintained also in i-model, use ItemTypes.
With regards,
Jan
