I have no problem in smooth view (or other render view), see left screen shot below. But when I insert points with Bentley Point Creator Plugin, the view is not good anymore, see right image. When I delete the points, the view return normal. Is there something I can do about it? I'm using Bentley Navigator V8i (SELECT series 6). Thanks
Changing to a front view using the toolbars, the new UCS is the same as the WCS https://testmyspeed.onl/ but is rotated 90 degrees about the X axis. This means the XZ plane of the WCS is being viewed; that is, the previous drawing plane edge is being looked at.
