Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
[Archived] Project Review Forum .i.dgn files
    • Sign In
    • Replies 4 replies
    • Subscribers 11 subscribers
    • Views 7384 views
    • Users 0 members are here
    • imodel package
    .i.dgn files
    Jared Mathes
    Jared Mathes over 13 years ago
    Currently we are still using MicroStation V8.5 and PlantSpace Design Series v8.5 to create model files.  We are interested in leveraging the power available in the new ProjectWise Navigator V8i.
    I have created a master dgn file of a project.  This dgn contains references to 95 other model files.  When I open the master dgn file in i-model composer and publish it to a package, it creates a separate i-model file for each reference in the same folder as the reference is located.
    This creates quite a mess.  Since both i-models and the regular model files both end in "dgn", they are listed one after another.  All I want is the package, not all of the intermediate .i.dgn files for each reference.
    It wouldn't be so bad if I could specifiy another folder for them to be created in, but it appears that the only folder designation is for the package itself.
    So, to clean up this mess, I need to go into all of the reference files folder, ctrl-click on each .i.dgn file and either move it or delete it.
    Is there something I'm missing here?  Is there a way to specify a separate folder for the reference file .i.dgn files or to not create them to begin with?
    Or maybe is there a way to give them a different file extension?  Something like "imd".  At least that way you could sort the folder view by file type and have them grouped together.
    • Sign in to reply
    • Cancel
    • Gary Cochrane
      Offline Gary Cochrane Wed, Nov 18 2009 7:30 PM
      Hi all,
      The behavior you are seeing is by design. This is new to me too, so I don't have all the answers yet, but:
      • When you create an i-model from a dgn with references, you will get an i-model for the dgn, and also i-models for each referenced dgn. The pointers in the "master" i-model will be modified to point to the i-model references, not the original DGN references.
      • When you (optionally) create a package, the process is essentially the same, except at the end, all the individual i-models are "compiled" into a single i-model package file. And as you noted, the individual i-models are not deleted after compilation.
      • Each individual i-model understands its lineage, so keeping the individual i-models will yield significant performance gains should the package be regenerated in the future. In that case, only DGN's that have been modified will be processed into new i-models. Any i-models that are still in sync with their original DGN files will not be regenerated.
      Hope this helps some,
      Gary
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Cancel
    • JordanH
      JordanH Wed, Nov 18 2009 8:42 PM in reply to Gary Cochrane
      I agree. I would like to specify the directory the i-models are placed in.
      Jordan
      • Cancel
      • Sign in to reply
      • Cancel
    • Jared Mathes
      Jared Mathes Thu, Nov 19 2009 4:00 PM
      Yes, that does help.
       However, it would really be nice if we could specify another folder for the created i-models.  Very messy as is.
      • Cancel
      • Sign in to reply
      • Cancel
    • Paul Johnson
      Offline Paul Johnson Thu, Nov 19 2009 7:09 PM in reply to Jared Mathes
      At this point there is no way to separate out the i-models at publish time.  They operate similary to the concept of a sister file at this time.  One thing you can do to help you organize them if you want to purge them from your system is to turn on the Created Date column in your details view of Windows Explorer.  Then you can sort by the Created Date and your i-models should filter out to the top\bottom of your list.  A little faster than CTRL-CLICK on every second file.
      ~Paul
      This is a test
      • Cancel
      • Sign in to reply
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
