Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
[Archived] Project Review Forum Bentley View SS2 and DWG 2010
    • Sign In
    • Replies 5 replies
    • Subscribers 12 subscribers
    • Views 4931 views
    • Users 0 members are here
    • Bentley View
    GeoEmp
    Offline GeoEmp over 13 years ago
    Hy.
    Installed the Bentley View SS2 and it's not openinf DWG 2010 files.
    Somewhere i read that all SS2 products can handel DWG 2010 versions.
    do i have to install realdwg201008110712en.msi (this is for SS1 versions!!!) to open DWG 2010?
    Or is there a SS2 version of realdwg???
    In MS SS2 the realdwg is included in the install, i sugsest that it wolud be good to do it also in Bentley View SS2
    Best
    • Sign in to reply
    • Cancel
    • Don H. Fu
      Offline Don H. Fu Fri, Aug 13 2010 1:43 PM
      Did you happen to have installed SS2 as a multi-installation?  If so, you need to go back to your extracted folder, find RealDwg2010.msi and install it manually.  Only single installation automatically installs all SS2 extensions including RealDWG 2010.
      If this is not your case, we need to know more information about your specific issue.  Usually a test file will help.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Cancel
    • Phil Chouinard
      Offline Phil Chouinard Fri, Aug 13 2010 1:44 PM
      Could you identify specifically how you installed Bentley View SELECTseries 2? Did you encounter any problems installing it or the RealDWG "plug-in"?
      • Cancel
      • Sign in to reply
      • Cancel
    • GeoEmp
      Offline GeoEmp Sun, Aug 15 2010 7:38 AM in reply to Phil Chouinard
      i just tried to install it again. Downloaded the setup 08.11.07.440 and nothing else. installed it on Windows 7 Ent 64 bit in Win XP mode. No realdwg is installed. included some screenshots and DWG 2010 file created with PoverCivil SS1 latest (realdwg installed Win 7 Ent 64 bit)
      View files.zip
      • Cancel
      • Sign in to reply
      • Cancel
    • Roy Gallier
      Offline Roy Gallier Mon, Aug 16 2010 5:06 PM in reply to GeoEmp
      Have you check to see if the program's installation folder exists?
      This is what it is for XP x64:
      C:\Program Files (x86)\Common Files\Bentley Shared\RealDwg2010
      • Cancel
      • Sign in to reply
      • Cancel
    • Phil Chouinard
      Offline Phil Chouinard Mon, Aug 16 2010 7:21 PM in reply to GeoEmp
      After further review, the current release of Bentley View V8i SELECTseries 2 supports the same DWG formats that SELECTseries 1 does. 2010 DWG files are supported in the current Bentley View V8i SELECTseries 2 by downloading the RealDWG 2010 "plug-in" from SELECTservices Online and installing that on Bentley View V8i SELECTseries 2.
      Another option to consider is to download and install ProjectWise Navigator V8i SELECTseries 2.
      • Cancel
      • Sign in to reply
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
