Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
[Archived] Project Review Forum Clash Detection Suppression Rules
    • Sign In
    • Replies 2 replies
    • Subscribers 11 subscribers
    • Views 3206 views
    • Users 0 members are here
    • Bentley Navigator
    • Navigator
    mmates
    Offline mmates over 11 years ago
    Using Bentley Navigator V8i SS3, I am looking for the proper way to setup a suppression rule to suppress clashes between elements on two specific levels.  I am self checking the entire structural model against itself.  So I setup the clash detection criteria by selecting the structural discipline master model reference and turn on Self Check.  Now I want to suppress clashes between the S-SLAB-EDGE and S-JNTS-EXPJ levels.  I can’t turn these levels off or select the criteria by other levels because I still want to find clashes between elements on these levels with other elements.  There is a template rule from the generic set that suppresses clashes with elements in specific levels, but I am not sure how to setup the “regular expression”.  The rule basically states:  Suppress clashes if the clashing elements are in a level that matches the regular expression <RegEx>.  Any help would be appreciated.
    • Sign in to reply
    • Cancel
    • Paul Johnson
      Offline Paul Johnson Tue, Nov 1 2011 7:37 PM
      Mark,
        There currently isn't a rule template that allows you to define a suppression rule for a clash between an element on LevelX and an element on LevelY.
      For the rule you are trying to use - you'd be supressing all clashes that have at least one element on either of the either of the two levels.
      I think your only choice is to set Criteria SetA by adding all the levels except S-SLAB-EDGE
      then for Criteria SetB by adding all levels except S-JNTS-EXPJ
      Also for information about Regular Expressions you can review the Navigator help or also look online (a good reference:  www.regular-expressions.info
      I'll add a request to the development team to look at adding a Rule Template for the example you outlined, suppressing a clash between two specific levels.
      ~Paul
      This is a test
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Cancel
    • mmates
      Offline mmates Tue, Nov 1 2011 9:16 PM in reply to Paul Johnson
      Paul,
      Thanks for the quick reply.  I was beginning to think it was not possible to suppress clashes between elements on different levels without turning the levels off or using the level selection criteria method.  I misunderstood the rule that you've explained.  Regarding your work around, I guess I could do that as a secondary check.  The other thing I'm considering is to mark those clashes as "accepted".  Thanks for the help.
      Mark Mates - BIM Manager - Mason & Hanger
      • Cancel
      • Sign in to reply
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
