Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
[Archived] Project Review Forum Publishing and Autogenerated (t1) extensions
    • Sign In
    • Replies 2 replies
    • Subscribers 10 subscribers
    • Views 1575 views
    • Users 0 members are here
    • i-Model Composer
    • imodel package
    • Links
    • ProjectWise Navigator
    • .pdf
    • ProjectWise
    • Revit
    • references
    Jim Youngblood
    Jim Youngblood over 11 years ago
    BeCommunities,
    When Publishing an i-model from Composer, as the reference files reside in PW, it appears in the process some files are being created with a (t1) extension automatically. Why is this occuring? Is this (t1) an issue which I should be concerned with?
    This process is Revit initiated. From Revit Native file > Bentley Add-in "publish to i-model" (we have PW integration issues thus the i-model is saved to my local, then copied into PW) > open a composer file from an i-model file within PW > New Composition (save to PW) > attach references > create Groups > add links > publish i-model > adjust settings per the 2nd snip attached below (here, is where the process autogenerates these (t1) extensions. And per the snip, the (t1) files are the reference files).
    My hard drive has 19GB of free space. - sorry if this is completely irrelivant. I am trying to think through ANY factors which may be causing this.
    • Sign in to reply
    • Cancel
    • Junaid Khan
      Offline Junaid Khan Thu, Aug 23 2012 8:58 AM
      Hi Jim,
      This is expected behavior, basically when you transform any existing i-model(s), IMC creates an intermediate published & transformed i-model by default with "t1, t2, t3 and so on as needed" added suffix so that it doesn't overwrite the existing i-models, and then embed those into a resulting package. You can use the option "Remove intermediate files after creating a package" from 'Package Settings' under Publish i-model dialog to delete those as desired.
      HTH,
      Junaid
      This is a test
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Cancel
    • Jim Youngblood
      Jim Youngblood Thu, Aug 23 2012 4:07 PM in reply to Junaid Khan
      Great news. Obviousely, I was worried over nothing.
      • Cancel
      • Sign in to reply
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
