Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
[Archived] Project Review Forum Imodel errors from sat/autocad files
    • Sign In
    • State Verified Answer
    • Replies 7 replies
    • Subscribers 11 subscribers
    • Views 3905 views
    • Users 0 members are here
    AndrewH
    Offline AndrewH over 9 years ago
    We use autocad 3d models extensively and a lot of the models display correctly in Microstation shaded modes but when an I-model is created and viewed in Microstation or Bentley View or Navigator  there are parts missing or they are shown in wireframe.  See the top of the vessel in the two screen shots.  The complete one is from Micrstation with the autocad file referenced in and displaying correctly.  The other one is the imodel and the top and bottom are missing.
    • Sign in to reply
    • Cancel
    • Darius Rimasauskas
      0 Offline Darius Rimasauskas Mon, Apr 14 2014 1:05 AM
      From your description looks like some objects are not published correctly. What version of MicroStation you have used?
      Would you be able to share your model (DWG + published i-model *.i.dgn)? If you do not what to share whole model, you may leave only faulting parts in it. If it is confidential you may upload to our Be Communities Secure File Upload
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • AndrewH
      0 Offline AndrewH Mon, Apr 14 2014 1:16 AM in reply to Darius Rimasauskas
      Hi Darius,
      Using Microstation 08.11.09.459 THe files are big so will put on the secure upload for you to have a look.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • AndrewH
      0 Offline AndrewH Mon, Apr 14 2014 1:26 AM in reply to AndrewH
      File uploaded Darius
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
      0 Offline Darius Rimasauskas Mon, Apr 14 2014 1:47 AM in reply to AndrewH
      Hi Andrew,
      I have seen similar issues, already reported to product developers.
      Try the following:
      Open your mixer.dgn in MicroStation and run Key-in: publishdgn converttoxgraphics off
      If you publish it now everything will look fine.
      This Key-in will turn xgraphics off. To turn xgraphics on again, just use “on” instead of “off”.
      Darius
      Answer Verified By: AndrewH
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
      0 Offline Darius Rimasauskas Mon, Apr 14 2014 3:04 AM in reply to Darius Rimasauskas
      Andrew, keep in mind that this solution is just a workaround and not a daily used solution.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
