Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
[Archived] Project Review Forum Projectwise/Bentley Navigator and PW
    • Sign In
    • State Not Answered
    • Replies 5 replies
    • Subscribers 11 subscribers
    • Views 5939 views
    • Users 0 members are here
    • navigator actor animation
    danny-cooley
    Offline danny-cooley over 9 years ago
    Hello
    At work we are using Bentley Mech, Arch, Structural, ..... SS2 with the project models/files hosted on Projectwise (can't immediately remember which version, but it is the correct one for BB Suite we are using)
    We have some 'co-ordination' files that we are using for clash detection. These files are empty and are just used to reference in the relevant design files.
    We then open these in Projectwise Navigator SS3. All the reference files are there, and the clash detection routines work fine.
    On issue though, we can't open the Reference files directly from within Projectwise Navigator. Meaning that when you select a Ref file in the Ref Manager, or by right clicking on it in the View Window, it does not give you the option to exchange to that file, or 'open in a new session'
    Is that normal?I can't find a Setting anywhere that allows you to activate this capability.
    Projectwise Navigator does seem to 'presume' that you will be using it with i-models. Does that have anything to do with it? (we haven't got around to using i-models yet)
    Is there a config somewhere that we have to set to enable PW Navigator to 'link-up' better with PW
    • Sign in to reply
    • Cancel
    • Junaid Khan
      0 Offline Junaid Khan Tue, May 6 2014 2:31 AM
      Hi Danny,
      Reference Exchange is i guess disabled in Navigator, as if you key-in "Reference Exchange" it doesn't ask you to select the DGN file from View for exchange unlike MicroStation. You will find the same behavior with i-model as well. Since Navigator Ss4, Desktop integration with ProjectWise Explorer is enabled automatically. For versions prior to that, you can add PW.cfg file from MicroStation's  to Navigator's config folder to automatically enable it from Desktop. After placing the file, you will know that ProjectWise integration is enabled if you see the ProjectWise Log in dialog when you launch the application, prompting you to select a ProjectWise datasource before you are prompted to select a file to open.
      Junaid
      This is a test
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Junaid Khan
      0 Offline Junaid Khan Tue, May 6 2014 2:33 AM in reply to Junaid Khan
      Required path for the CFG file for Navigator
      C:\Program Files (x86)\Bentley\Navigator V8i\Navigator\config\appl\pw.cfg
      This is a test
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • ChrisRevuelta
      0 Offline ChrisRevuelta Wed, Aug 26 2015 11:19 AM in reply to Junaid Khan
      in relation to this, I am unsure which way to go - desktop integration OR start Navigator from within PW... I know both are possible, but Navigator under a managed workspace configuration (all my projects inherit the managed workspace from the project folder) for me doesn't work properly yet... there must be some configuration blocks that work for ABD but prevent Navigator from starting... However, using Desktop integration seems inconsistent with using PW so I would prefer using Navigator from within PW... help!
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • danny-cooley
      0 Offline danny-cooley Fri, Sep 18 2015 8:23 PM in reply to ChrisRevuelta
      Chris
      I can only symphise at this point
      We are using Navigator SS4, but an earlier version of PW (SS2 but I'll have to check)
      The problem is, PW is provided and set up by the client, but we (the consultants and contractors) are left to install Navigator ourself and we have restriced access to the C drive so we can't do anything regarding pcfs and so on.
      I would have though that using Navigator from within PW was a preferable approach as we are supposed to 'pushing' to get PW being used by all concerned as the 'front end' or main interface for all the project models, drawings, docs, info, ect, ...
      Chris, ..... have you tried selecting the imodel (are you using imodels), .... or the co-ordination file for Clash Detection (guessing you have something like that set up???????), then via the Properties Dialog Box, chosing Navigator as the application to use?
      Do you see what I mean?
      Danny Cooley
      Freelance AEC CAD/BIM Technician Architecture, MEP & Structural  ..... (& ex Low Carbon Consultant, ..... because they weren't that bothered!)
      OBD Update 10, Windows 10 Pro, HP Z4-G4, 64Gb, Xeon 3.6GHz, Quadro M4000
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • ChrisRevuelta
      0 Offline ChrisRevuelta Fri, Sep 18 2015 10:20 PM in reply to danny-cooley
      Danny, you may want to check also how I solved my wee problem - may not be relevant to yours but still...
      communities.bentley.com/.../337321
      cheers
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
