Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
[Archived] Project Review Forum iModel file - Views disappear when processed by Navigator Mobile Publisher
    • Sign In
    • State Not Answered
    • Replies 10 replies
    • Subscribers 12 subscribers
    • Views 5981 views
    • Users 0 members are here
    Anthony Charnley
    Offline Anthony Charnley over 9 years ago
    Anyone come across this?
    I have a 5MB Microstation file (contains a zMapping reference file) which I previously was able to view on my iPad Air via NMP.
    It looked terrible - garish colours- and all the views were not as desired, so I went back and changed the original file to simplify the colours. Tried to delete the existing saved views, then created 18 new ones, published it to iModel with Microstation v8i SS3 and then published it again using NMP.
    When I load the file either within NMP or on the iPad it is an 'empty' file - no views there to click on and load.
    Any thought as to what can be the problem / how to solve it? I can see the file and all its views fine in a 3D PDF using the 'Print to 3D' function.
    • Sign in to reply
    • Cancel
    • Darius Rimasauskas
      0 Offline Darius Rimasauskas Tue, Jul 15 2014 6:43 AM in reply to Anthony Charnley
      What is the exact version of MicroStation 8.11.09.xxx?
      What file size you get of single i-model package *.i.dgn? - I get 140610_3D .i.dgn = 3.96 MB (4,158,976 bytes)
      When publishing with Navigator Mobile Publisher, does it generates *..idgndb-issues.log file? What issues it reports?
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Anthony Charnley
      0 Offline Anthony Charnley Tue, Jul 15 2014 6:51 AM in reply to Darius Rimasauskas
      Microstation version is 08.11.09.292
      *.i.dgn size on disk is 4.12 MB (4,329,472 bytes)
      No log file generated that I can see - but where would I look for it?
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
      0 Offline Darius Rimasauskas Tue, Jul 15 2014 7:14 AM in reply to Anthony Charnley
      *.idgndb-issues.log file is placed in same directory as your new *.imodel publishes. But it is saved only if issues were encountered. After publish completes in Navigator Mobile Publisher dialog it shows publish finished and if issues found it displays them there too.
      Can try reinstalling Navigator Mobile Publisher, maybe something with the installation itself. Because same version works fine on my side (Windows 7 with SP1)
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Anthony Charnley
      0 Offline Anthony Charnley Mon, Jul 21 2014 1:08 PM in reply to Darius Rimasauskas
      I have removed NMP and re-installed from a FRESH download from Bentley's Select site. Still the same result! Only 33Kb file generated. What to try next?
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Anthony Charnley
      0 Offline Anthony Charnley Tue, Jul 22 2014 1:20 PM in reply to Anthony Charnley
      Tried using simpler / different models to no avail - NMP seems to stop writing the file at  33KB every time.  PLEASSE PLEASE suggest something else to try? Must be a setting in the file?
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
