Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Deliverables Management Forum Change the Transmittal/Submittal form
    • Sign In
    • State Verified Answer
    • Replies 2 replies
    • Subscribers 8 subscribers
    • Views 175 views
    • Users 0 members are here
    Luc Poulin
    Offline Luc Poulin 1 month ago
    I'm being ask to change the transmittal/submittal form use for review
    Is this possible?
    Change being ask is add a field, remove another one or event have two form based on the type of review
    Also some of the fields are gray out and we would like to have them available at any point in time of the process. I understand that when in unresolve-Draft the reviewer can change them, but when back to the issuer we would like to have them update one of the field.
    Also is there a place where we can see the intent use of those field in a real life scenario?
    Example:
    » If the field Response is set to Agree, but the document is mark as reject in the review, it kind of give a conflict information.
    » In the field Level «...1 - Comments and/or general remark. Refers normally to editorial mistakes...» not sure where this phrase would be used and in which context?
    • Sign in to reply
    • Cancel
    Top Replies
    • Justina Jureviciene
      Offline Justina Jureviciene Wed, Oct 18 2023 8:03 AM +1 verified
      You can modify the default submittal issue form or create a new form in Forms service. All the approved forms under Submittal Issue section will be visible when performing PDF reviews in Deliverables…
      +1 Offline Justina Jureviciene Wed, Oct 18 2023 8:03 AM
      All the approved forms under Submittal Issue section will be visible when performing PDF reviews in Deliverables Management service.
      Submittal Issue attributes modification is only possible when issue is in Unresolved-draft state. Once it is sent with initial response for the document, the issue attribute values cannot be modified. You can only comment on it, add attachments and change it state.
      Answer Verified By: Luc Poulin
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Reject Answer
      • Cancel
    • Luc Poulin
      0 Offline Luc Poulin Wed, Oct 18 2023 8:16 AM in reply to Justina Jureviciene
      Thank you @justina
      I guess I need to log an enhancement to have the possibility to modify the form behaviour and the  workflow as well....
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    Reply
    • Luc Poulin
      Thank you @justina
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
