SharePoint/ProjectWise Web Server Single Sign On Setup
I am trying to set up single sign on for SharePoint/Web Parts but I am running into a road block. I have followed the technotes and the implementation guide to set everything up but user permissions aren't carrying through as I would expect.
I set up a delegate user to log on to the web parts expecting that other users who log on to the site will only see the projects/folders they have rights to see but this doesn't seem to be the case. Other users are still able to see everything the delegate user can see which we don't want. The delegate user has been enabled as a delegate user through PW admin, configured them as the delegate user on the Web Servers, and we have added the SharePoint Servers to the trusted server section in the Integration Server's dmskrnl file.
Any help would be appreciated by anyone who might have had some similar issues with this setup.
Jutin
  • Hi Jutin,
    From the explanation of the issue I would suspect that you have used that delegate user in the SharePoint site configuration (that this delegate user would be used to log in).
    Actually you should set up this delegate user only over the ProjectWise Web Server Delegate User configuration (that can be found in Start menu under ProjectWise Web Server). And when you are configuring SharePoint web parts you should enable the SSO option for the web parts that you add (not the delegate user). This way the user Windows login will be used to access ProjectWise and delegate user will be used to check the user details. As a result each user will have the own access that was set.
    Mantas
    This is a test
