Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Setting up the Apache Chainsaw viewer for viewing Projectwise Orchestration Framework Logs
    • Sign In
    • State Not Answered
    • Replies 2 replies
    • Subscribers 58 subscribers
    • Views 2463 views
    • Users 0 members are here
    • Chainsaw Orcehestration Framework Log Logging
    PM68
    Offline PM68 over 9 years ago
    We are using Projectwise V8i Select Series 3. I am attempting to setup Apache Chainsaw Viewer to view the Orchestration logs by following the Projectwise Orchestration Framework V8i Logging Technote. I believe I have set up everything correctly except the document refers to a "LoggingServiceChainsaw.xml" file that should be in c:\documents and settings\all users\application data\bentley\logs" I have searched the server and it is nowhere to be found.
    Am I missing something or is it just missing from our installation and if so any ideas where I can get it from.
    Thanks in advance
    Peter
    • Sign in to reply
    • Cancel
    • Marty.Nickel
      0 Offline Marty.Nickel Fri, Sep 12 2014 10:36 AM
      Is there a reason you are using the chainsaw viewer?  I've reviewed hundreds of OF logs and I have never used this.  I always just review the loggingservice.log files here on a server 2008:  C:\ProgramData\Bentley\Logs
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Dean Lyon
      0 Offline Dean Lyon Mon, Sep 15 2014 4:41 PM in reply to Marty.Nickel
      The logs for Orchestration Frame work should be on the server where it is installed.  We are now using 2008 as well but that does seem correct when we had Server 2003.  The Orchestration Framework should set up the logs directory, but the .log file goes there. not the .XML. You should find the ???.log.xml files either in the ProjectWise directory or in the Orchestration Framework directory.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
