Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum PW local workspace copy - behaviour/when to purge?
    • Sign In
    • State Verified Answer
    • Replies 6 replies
    • Subscribers 59 subscribers
    • Views 9254 views
    • Users 0 members are here
    • ProjectWise
    • workspace
    • Configuration Variables
    • copy out
    Thorsten B
    Offline Thorsten B over 8 years ago
    Hi All,
    we're running PW with integrated Microstation, OpenPlant Modeler etc.
    I understood that, when opening documents from within PW explorer they are copied to local - along with their related workspace files.
    In our workspace we had recently added a new DGNLIB and removed an old one. I experienced, that setting from the old DGNLIB was still "active".
    While browsing through the local copy of the workspace I found out, that the old file is still stored locally, and the new file is in the same directory.
    In case of workspace configuration variables that point to paths instead of files a.m. behaviour ends up in applications using old and new configuration settings together.
    My expectation was, that the local workspace in use is always looking like the PW stored workspace. In fact, the local workspace is a sum of workspaces.
    Is something wrong with PW workspace download/local copies? Or do I have to ask all users to purge their local workspace, whenever I made change?
    BTW: When should local workspace be purged in general?
    Thanks for your answers in advance.
    Thorsten.
    • Sign in to reply
    • Cancel
    • Dean Lyon
      0 Offline Dean Lyon Thu, Sep 18 2014 2:54 PM
      Hi Thorsten,
            When a user opens a file that has a managed workspace, it updates the files from the server that have changed. I am not aware of a setting that will make it remove files during that syncronization that are removed in ProjectWise. In Explorer if you delete the file in ProjectWise, it does not delete the copies of that file off of computers that the file has been copied to.  At that point it becomes an unmanaged file where it has been copied.  I suspect that the workspaces work in a similar fashion. They will let you update a file from PW when you sync. I don't know of a setting that will totaly mirror the files during a sync, removing files that were removed from ProjectWise.  Post the version of ProjectWise that you are using and someone may know if that version has a setting or not.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Thorsten B
      0 Offline Thorsten B Fri, Sep 19 2014 4:00 AM in reply to Dean Lyon
      Thanks DeanLyon.
      My PW version is 08.11.11.574 (Ss4).
      Does anyone know a switch, that syncs local with PW-stored workspace?
      If there's none, I would say it is a bug of the managed workspace feature, because settings from local could overrule settings from PW without further notice.
      In the meantime I have to advise all users in my CAD Environment to purge their entire workspace, whenever I removed a file in PW workspace.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Scott M. Turner
      0 Scott M. Turner Sun, Sep 21 2014 6:37 PM in reply to Thorsten B
      Hi Thorsten,
      I am not aware of any switch to do this.  The managed workspace functions essentially as a copy out, which means the files are unmanaged in terms of ProjectWise.
      We've run into the exact same situation as you have.  Fortunately the group wasn't large so getting the word out to purge the workspace was easy, albeit a bit frustrating.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Thorsten B
      0 Offline Thorsten B Mon, Sep 22 2014 3:28 AM in reply to Scott M. Turner
      Thanks for this information, Scott.
      We have teams on 3 continents (US, Europe, Asia) running the same PW. For me it is not only a bit frustrating.
      I hope Bentely considers this behaviour as an issue. Or they should address their advertisment to small companies/teams.
      Regards.
      Thorsten.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Thorsten B
      0 Offline Thorsten B Tue, Sep 23 2014 3:52 AM in reply to Thorsten B
      Update: I issued a service ticket at Bentely.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
