Error when running Iplot distribution job: Failed -- ProjectWise error creating folder "XXXXXXX". ProjectWise error message: Internal error. Insufficient information passed to dmsapi.
Hi guys,
Receive the following error when running an Iplot distribution job:
Failed -- ProjectWise error creating folder "Contracts".
This is the error shown in the Orchestration Framework / Distribution Service window.
Anyone have any ideas?
The job itself is taking a DGN from a folder location in ProjectWise, and distributing a PDF in to another folder area - it is configured to create a matching folder path but this seems to be a problem.
This is being done as testing - our existing Iplot servers work fine and can distribute and create folders with no issue - but are running on Server 2003 (x86). This error occurs on a box running Server 2008 R2 (x64).
It can distribute a PDF to a folder that already exists with no issue, but folder creation seems to be an issue.
This is using ProjectWise SS2. Am I missing a configuration step or is there some other issue?
  • The distribution service uses a given projectwise user to push the pdf file back into projectwise.
    Can you login to a projectwise explorer session running on the server 2008 box using this user
    -sometimes the woking directory is missing or like and generates an error
    -then when logged in projectwise organiser as this user create the folder path in question yourself
    - this given user must have create folder rights or an error will be generated
    errors generated like this do not allways find their way into the iplot DS system as a clear message.
