Yesterday I found the Bulk Load Tool for uploading bulk to Project Wise.
I am hoping to upload to different PW folders in one DAT file.
Document 1, Project number = long32:3300
Document 2, Project number = long32:913
But when running the "Process Bulk Load File" Tool, it prompts for a specific "Parent folder" and uploads the Documents to that specific folder (Project).
What have I missed?
Thank you.
Kevin.
I have a feeling that the Process Bulk Load File Tool is only intended to create folders (projects) and sub-folders and upload documents to the newly created folders.
Looks like you cannot add Documents to existing sub-folders with this Tool .. If you can then PLEASE show me how.
This DAT file worked for me, it created the sub-folders and placed documents in sub-folders.
(ignore the Original Path properties of the PROJECTS... )
[BULKLOAD]Only Files=0
[PROJECT_1]Name=DrawingsDescription=DrawingsParent=Original Path=C:\DrawingsParent Number=Project Number=Used Name=DrawingsManager=barnkStorage=Storage
[PROJECT_2]Name=ModelDescription=Parent=Original Path=C:\Drawings\7109Parent Number=Project Number=Used Name=ModelManager=barnkStorage=Storage
[PROJECT_3]Name=DesignsDescription=Parent=PROJECT_2Original Path=C:\Drawings\7109Parent Number=Project Number=Used Name=DesignsManager=barnkStorage=Storage
[DOCUMENT_1]Original Path=C:\Drawings\7109\10\Models and Systems\02\7109.10.02B001.dwgName=7109.10.02B001.dwgDescription=7109.10.02B001FileName=7109.10.02B001.dwgProject=PROJECT_1Project Number=Document Number=Used Name=7109.10.02B001.dwgUsed FileName=7109.10.02B001.dwgStorage=Storage
[DOCUMENT_2]Original Path=C:\Drawings\7109\10\Models and Systems\02\7109.10.02B002.dwgName=7109.10.02B002.dwgDescription=7109.10.02B002FileName=7109.10.02B002.dwgProject=PROJECT_3Project Number=Document Number=Used Name=7109.10.02B002.dwgUsed FileName=7109.10.02B002.dwgStorage=Storage
[PROJECTS]PROJECT_1=PROJECT_2=PROJECT_3=
[DOCUMENTS]DOCUMENT_1=DOCUMENT_2=
Answer Verified By: Marty.Nickel
