Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum ICS Ad Hoc Rendition Job
    • Sign In
    • State Verified Answer
    • Replies 11 replies
    • Subscribers 61 subscribers
    • Views 4809 views
    • Users 0 members are here
    • iCS
    • Renditions
    • ProjectWise
    Finn Mejding
    Offline Finn Mejding over 9 years ago
    I have inherited a configuration done by another user and I am unable to read this information anywhere in the documentation, so I am relying on the wise users in this forum.
    The Question is regarding the job definition for ad hoc renditions for ICS.
    When I Create a rendition from my ProjectWise Explorer by right-clicking on a dgn file and selecting Submit, a job is submitted and queued on the Orchestration Framework Server.
    I can see the job in the OF Administrator module, but the job is stucked in Idle mode.
    I have, by editing the job in OFA, found that the "Input Files" tab is set to a saved search and not my selected dgn file.
    Is there any configuration variable that set this value?
    How do I find this default setting so I can change it ?
    It is obviously wrong the Input File tab for the job in OFA, should have shown a path to a single file and not a saved search.
    Have anyone in here any idea where to find the definition?
    Thanks in advanced
    Finn
    • Sign in to reply
    • Cancel
    • Arturas Zidonis
      0 Offline Arturas Zidonis Mon, Dec 8 2014 3:50 AM in reply to Finn Mejding
      Hi Finn,
      Could you also check the exact version of OS (Windows Server 2008 SP2, or Windows Server 2008 R2, etc..) on the server where PW iCS jobs are running?
      This is a test
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Finn Mejding
      0 Offline Finn Mejding Mon, Dec 8 2014 4:07 AM in reply to Arturas Zidonis
      Hi Arturas
      The server version is: Windows Server 2008 R2 Standard Version 6.1 (build 7601).
      After doing some more investigation, I have discovered that if I manually submit the job in OFA anyway (even if the source is a saved search that do not exists anymore) there is actually created a pdf of the dgn submitted. Strange, but it works, and I can live with that. I checked the database to se what was written in the table dbo.rendscvJobInputSet and there was the right URL to the dgn file I created the rendition for.
      The last problem I have with this ad hoc rendition is that the job isn't starting automatically, and since it have the date and time as its name, I cannot schedule the job.
      How do I ensure that the job actually runs on the OF server?
      Finn Mejding
      CAD Manager
      Railway and Metro
      COWI
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Arturas Zidonis
      0 Offline Arturas Zidonis Mon, Dec 8 2014 4:32 AM in reply to Finn Mejding
      The job should always start automatically when submitting from PW Explorer. I think you should be looking in initial problem because I don't think there is some way to ensure that those jobs run automatically.
      In first place I would try restarting OF service. If that doesn't make any difference then restart the server. If the issue will still occur then need to increase OF logging and see if there is more information on the issue.
      This is a test
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Finn Mejding
      0 Offline Finn Mejding Tue, Dec 9 2014 4:24 AM in reply to Arturas Zidonis
      Hi Arturas,
      I have now tried to restart the OF service and the integration server itself, but this had made no different.
      Can you tell me how to increase the logging on the OF, so I can get more info?
      Finn Mejding
      CAD Manager
      Railway and Metro
      COWI
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Arturas Zidonis
      0 Offline Arturas Zidonis Tue, Dec 9 2014 5:04 AM in reply to Finn Mejding
      You can increase the logging by updating OrchFwrkLogging.config file on your server in this directory C:\Program Files (x86)\Bentley\OrchestrationFramework.  Find attached file.OrchFwrkLogging.zip
      This is a test
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
