Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Setting the default startup folder
    • Sign In
    • State Verified Answer
    • +1 person also asked this people also asked this
    • Replies 6 replies
    • Subscribers 64 subscribers
    • Views 12140 views
    • Users 0 members are here
    Captured to Setting the default startup folder wiki page
    Stephanie Doherty
    Offline Stephanie Doherty over 8 years ago
    Does anyone know if there is a way to specify the starting folder that ProjectWise Explorer opens when the application starts, or if there is a way to automatically start it to open the last folder the current user opened before PW was last closed? We seem to get random results as to which folder opens when we start PW.
    Stephanie
    • Sign in to reply
    • Cancel
    • Jon Evans
      0 Offline Jon Evans Tue, Dec 2 2014 2:13 PM
      It should automatically goto the last folder you where in when closed, if it is not Close Projectwise and browse to here: C:\Users\"YourUser"\AppData\Roaming\Bentley\ProjectWise\Cache and delete any files located within this folder.
      restart Projectwise and it should then once again store the previous folder info correctly.
      Answer Verified By: Stephanie Doherty
      • Cancel
      • Vote Up -1 Vote Down
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    • Jeff Burrill
      0 Offline Jeff Burrill Tue, Dec 2 2014 3:35 PM
      ProjectWise will open in the last used folder of a datasource for a user after login IF their account is set to do that. In the user account properties, go the Settings tab, expand User Interface section, and make sure the check box is on for "Select last used folder in ProjectWise Explorer". HTH
      Please note that I post here on a voluntary basis and am not a Bentley employee.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    • Dean Lyon
      0 Offline Dean Lyon Wed, Dec 3 2014 1:25 PM in reply to Jeff Burrill
      It has been my experience that it goes to the last folder an action was performed in or on. If you just go to look at a folder and open the property dialog, it is not enough to be "last visited". (if the setting for the user has been turned on).  I have also found that the last used for iDesktop plugins have their own recently used  or last used list.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Ignacio Merino
      0 Offline Ignacio Merino Fri, Jan 25 2019 6:53 AM in reply to Dean Lyon
      Hi, is there a command line i can add to the program shortcut in order to set as startup directory the default MS_DEF or _USTN_PROJECTWORKFILES directory? I do know it's possible to set the default user by adding the -wcUSERNAME & the default project using -wpPROJECTNAME, is there something similar for the startup directory? Thanks
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • johnny douglas
      0 Offline johnny douglas Mon, Jan 28 2019 1:14 PM
      its good to
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
