Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum ProjectWise Import from Excel - problem with creating new versions
    • Sign In
    • State Verified Answer
    • +2 person also asked this people also asked this
    • Replies 5 replies
    • Subscribers 63 subscribers
    • Views 5879 views
    • Users 0 members are here
    • Import tool
    • Versions
    Suzette Delavega-Edmondson
    Suzette Delavega-Edmondson over 8 years ago
    All,
    I am trying to import files from a local drive to a ProjectWise folder using the Import from Excel tool.  The Excel file is populated correctly, however, when trying to import a new version of an existing document, I get this error:
    01/12/15 11:00:19] Creating document...
    [01/12/15 11:00:19] ERROR: [ 58028 ] Error creating new document. The file name is already used in this folder. Change the file name and try again.
    I have the options to create new document and create versions of existing documents checked.
    Why is ProjectWise not creating a new version and giving me this error?  I thought it is meant to create a new version when the file name and name of a file being imported are the same as the file name and name of an existing document?
    Thanks for your help,
    Suzette
    • Sign in to reply
    • Cancel
    Top Replies
    • Kestas
      Offline Kestas Mon, Jan 19 2015 7:45 PM in reply to Suzette Delavega-Edmondson +1 verified
      Hi Suzette, I found "Folder Name" column values is required to be filled in addition to the "File Name" and "Name" when creating new version. If you specify destination folder in the import wizard …
    • Suzette Delavega-Edmondson
      0 Suzette Delavega-Edmondson Mon, Jan 19 2015 4:22 AM
      Hi Bentley team - can someone from tech support get back to me re this issue, please? We need to start bulk uploading soon, including uploading new versions of existing documents.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • JackiS
      0 Offline JackiS Mon, Jan 19 2015 9:05 AM
      Suzette:
      I would double check and do a search to make sure that the files and/or versions are not already there if you tried running the import several times.  Also, put the files in order and put a version number in the spreadsheet.  The order is oldest to newest.
      http://communities.bentley.com/products/projectwise/content_management/w/wiki/12654.right-click-document-folder-export-tools-export-import-wizard-export-import-with-excel-tn
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
      0 Suzette Delavega-Edmondson Mon, Jan 19 2015 9:13 AM in reply to JackiS
      Jacki
      I have already done all of those, I even waited for a day to see if the new version appeared, but it did not. I also tried not filling in AND filling in the version number in the import spreadsheet, importing the oldest first; but using both methods, I still get the error message:
      Suzette
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Kestas
      +1 Offline Kestas Mon, Jan 19 2015 7:45 PM in reply to Suzette Delavega-Edmondson
      Hi Suzette,
      I found "Folder Name" column values is required to be filled in addition to the "File Name" and "Name" when creating new version. If you specify destination folder in the import wizard (by click Browse) then type "\" in the "Folder Name" of your load sheet. "Version" column may not be mandatory. If you specify the value in "Version", then version value should not be already taken for that document yet, if you remove "Version" column out of the load sheet PW should generate next one based on your datasource setting either next Alpha or Numeric if it is set so.
      Hope this helps,
      Kestutis
      Answer Verified By: Madhuri Londhe
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Reject Answer
      • Cancel
    • 71B09C1F-8906-40D6-A7EF-4DAA890BDEA3
      0 Offline 71B09C1F-8906-40D6-A7EF-4DAA890BDEA3 Tue, Nov 14 2017 8:35 PM
      Bentley,  I has submitted my ticket. Still no response.  Its been 4 days now.   I got the same issue.
      7000697523
      7000704216
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
