Asterisk in column header
In some views I see an asterisk to the right of the text in the column header. Anybody knows what that means?
  • Hi,
    As I see you seem to be using ProjectWise Environment attributes in the view. And the column name that you see in the view is set the same as the environment attribute name in the interface.
    You could go to ProjectWise Administrator, select the environment, expand Attribute layout (and select appropriate interface), find the attribute that you have in question, open properties and select Interface dialog. There you should see the Label Text value that should be called same as you see in the view.
    Like here:
    Mantas
    This is a test
    Answer Verified By: Leif Frederiksen
