Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum how to install projectwise ss4 on a fresh windows server 2008?
    • Sign In
    • State Verified Answer
    • Replies 5 replies
    • Subscribers 60 subscribers
    • Views 2550 views
    • Users 0 members are here
    • Bentley Institute
    • administrator
    • Administrator v8i SS4
    • Bentley Architecture and ProjectWise
    • ProjectWise
    • 64 bit
    • Caching Server
    • Configuration
    JessieMCS
    Offline JessieMCS over 8 years ago
    can you please show me the procedures or the steps to follow the right way to setup and configure projectwise ss4?
    thanks in advanced.
    Jessie
    • Sign in to reply
    • Cancel
    • Dana Guthrie
      0 Offline Dana Guthrie Mon, Feb 23 2015 10:16 AM
      There is an Implementation guide that is delivered with Projectwise Server setup software. This document should give you all the information you need for pre-requisites, and guide you through the install of each of the services.. If you have an existing setup, then take notes of which software is installed , and then only deploy the same software on the new server.. The implementation guide gives directions for all the Projectwise software, so you will need to read carefully and only install what you need. If you are upgrading to a new version of Projectwise as well then see the very end of the implementation guide about upgrading as there are steps you will need to take in converting the database. If you are getting ready to upgrade, then I strongly suggest contacting Bentley Managed Services to help you with the process.
      Answer Verified By: Dana Guthrie
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Reject Answer
      • Cancel
    • JessieMCS
      0 Offline JessieMCS Wed, Mar 4 2015 2:02 AM in reply to Dana Guthrie
      thanks for the reply. I've managed to install projectwise ss4 on my windows server 2008 but my next question is...how do I import all of my existing files and folders onto projectwise such as word, excel, cadd, gdn files and others?
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Dana Guthrie
      0 Offline Dana Guthrie Wed, Mar 4 2015 8:12 AM in reply to JessieMCS
      I will need a little context here to answer this question. Is this a brand new instance of ProjectWise with no documents or folders in PW? Or did you upgrade from a previous version with a datasource that is already populated with some of your data?
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • JessieMCS
      0 Offline JessieMCS Wed, Mar 4 2015 8:32 AM in reply to Dana Guthrie
      yes. it's a brand new instance of PW with no documents or folders in PW. How to begin? what should I do first? thanks
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Dana Guthrie
      0 Offline Dana Guthrie Wed, Mar 4 2015 8:40 AM in reply to JessieMCS
      The easiest way is to drag and drop the folders and or files from the desktop write into ProjectWise. However there is more to just adding folders\and files to ProjectWise. Before adding folders and files to PW, you will need to setup storage areas, environment attributes, security, etc... May I suggest you review some of the training videos on line, and or consider signing up for a ProjectWise Admin and User course.
      Here are a few links to get you started
      Bentley site tells about training opportunities: www.bentley.com/.../Training
      Main learn server site: learn.bentley.com/.../Public
      ProjectWise Learn server Courses:
      learn.bentley.com/.../BrowseLearningPaths;CustomLP=False
      In the ProjectWise track look for ProjectWise Administrator basics, and ProjectWise Explorer Basics, ProjectWise user tips and tricks, ProjectWise Administrator and ProjectWise administrator tips and tricks
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
