Tendering or Contract partners will quite often supply us with (cd or usb-sticks with) documents in a complicated structure of folders and subfolders, using long names for folders and documents. Thus exceeding the limited Windows path of +- 255 characters.
When trying to drag&drop the folder structure in PW this gives errors (and lots of frustration too)
How do others deal with this? Shortening the path name is a very time-consuming labour; besides we usually are not allowed to change document names, that come from the partner's EDM system. We also need to keep the file complete in the structure it is delivered to us.
Any help is appreciated!
Have you tried ‘Long Path Tool’ ?it’s very useful in this type of case.
Thanks for Shearing information, We too Face same problem, Actually this problem started for any New project which is done by any Main vendor/ contractor they fallow there own software and Document Hierarchy and once they handover document in Hard disk or DVD's Or USB's and thy close project, problem is found Once Document controller or team starts Uploading such long file or folder name . Solution is copy All main folders to any of your free Location folder wise . and start Rename and Short Forder /file name. Example- pre commissioning/ mechanical documentation/ administration building/ file name is also long......xxx. so in this case u can do PreCom/Mech Doc/Admin BLD/ same reduce file name,....using windows each file folder one by one,, of if u r DOS expert u can do it as Batch wise,,, rename,,,,
Not Yet. i checked with Some friends with EX organization they Suggest, to rename in command prompt DOS, for GroupWise, other wise windows explore it may take time. .. Please Suggest ,any method you have done to solve ,,,
