Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Removing Projectwise from Autocad 12, 13, etc.
    • Sign In
    • State Verified Answer
    • Replies 2 replies
    • Subscribers 60 subscribers
    • Views 6590 views
    • Users 0 members are here
    • AutoCAD 2013
    • AutoCAD 2012
    • civil 3d 2014
    • AutoCad
    • Autodesk
    • Civil 3D
    Albert LeBlanc
    Offline Albert LeBlanc over 8 years ago
    How do I remove Projectwise from Autocad, without uninstalling Projectwise from the computer?  Projectwise interferes with how Autocad works (mostly "Save" and "Save as" commands), even on drawing files that do not involve Projectwise.  I have clicked on the "Disable" button under the Projectwise menu in Autocad, and I used the "DMSOFF" command to disable it in Autocad, but Projectwise continues to interfere. I need to keep Projectwise for Microstation projects, so I don't want to uninstall it, but I do need to completely remove it from Autocad. Thanks for your help.
    • Sign in to reply
    • Cancel
    • Dean Lyon
      0 Offline Dean Lyon Tue, Mar 3 2015 8:35 AM
      Go to the Control Panel, Programs, uninstall program. Click on ProjectWise and choose remove. When the diaolog comes up, you will have the option to Modify. Choose Modify. On the next screen open the iDesktop branch and disable AutoCAD integration, follow through the rest of the screens and install/finish. I believe there is a way to do this with the msi command line switches if you have to do it on lots of computers.
      Answer Verified By: JackiS
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Reject Answer
      • Cancel
    • Albert LeBlanc
      0 Offline Albert LeBlanc Tue, Mar 3 2015 11:51 AM in reply to Dean Lyon
      Thanks! That did the trick. Autocad is back to normal, and I can still use Projectwise with Microstation. Thanks again.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Reply
    • Albert LeBlanc
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
